Saltar al contenido principal
Ematic EGQ307 Battery Replacement
Qué necesitas
  1. Ematic EGQ307 Battery Replacement, Battery: paso 1, imagen 1 de 2 Ematic EGQ307 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
  2. Ematic EGQ307 Battery Replacement: paso 2, imagen 1 de 2 Ematic EGQ307 Battery Replacement: paso 2, imagen 2 de 2
    • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
    • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
  3. Ematic EGQ307 Battery Replacement: paso 3, imagen 1 de 1
    • 3. Once you pry off the plastic backing, you will expose the battery.
  4. Ematic EGQ307 Battery Replacement: paso 4, imagen 1 de 3 Ematic EGQ307 Battery Replacement: paso 4, imagen 2 de 3 Ematic EGQ307 Battery Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • 4. Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LED. Pry the battery off the LED using a plastic card.
    • Do not bend or warp the battery. Even though the battery may not be working, it is still dangerous.
  5. Ematic EGQ307 Battery Replacement: paso 5, imagen 1 de 1
    • If replacing the battery, unplug the black and red wires gently from the hardware and take off the battery .
    • If not replacing it, do not disconnect the red and black wires.
    • If replacing the battery, you will need a soldering kit to reconnect the wires with the new battery after disconnecting the old battery.
    • How To Solder and Desolder Connections.
Conclusión
To reassemble your device, follow these instructions in reverse order. Note, you need to solder the battery wires onto the motherboard.
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 5,122
