Saltar al contenido principal
Elenco Auto-Scan FM Radio Model FM-88K Capacitor 22 Replacement
Qué necesitas
    • Remove the battery and the antenna.
    • Pre-heat the soldering iron.
    • Place hot solder iron on thermal pad, capacitor lead, and the mound of solder until solder liquefies.
    • Apply desoldering pump to remove the solder from the circuit board.
    • Repeat the instructions to remove solder from the adjacent solder mound.
    • Gently remove the capacitor by pulling the two leads out of the circuit board.
    • Place the leads of the capacitor through designated holes of the circuit board.
    • Place solder iron on the thermal pad and the lead.
    • Once this is done wait a few seconds until both items heat up.
    • Once they are heated, apply the solder to the other side so that the solder iron and the solder are not directly touching.
    • Wait 3 to 5 seconds or until enough solder covers the whole pad and forms a nice mound.
    • Remove the solder, leaving the solder iron on the pad for 2 to three seconds, then remove the solder iron.
    • Repeat for the other lead.
    • Plug the battery in and attach the antenna to test the radio.
Conclusión
4 personas más completaron esta guía.
Charles Riel
Miembro Desde 10/10/14
218 Reputación
1 Guía escrita
Equipo
Charlie Riel Miembro de Charlie Riel
Community
1 Miembro
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 1,029
