Saltar al contenido principal
Element GC-1020 Battery Replacement
Qué necesitas
  1. Element GC-1020 Battery  Replacement, Back Cover Replacement Guide: paso 1, imagen 1 de 1
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
  2. Element GC-1020 Battery  Replacement: paso 2, imagen 1 de 1
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
  3. Element GC-1020 Battery  Replacement, Battery: paso 3, imagen 1 de 2 Element GC-1020 Battery  Replacement, Battery: paso 3, imagen 2 de 2
    • Then remove the battery from the device through soldering the black and red wires connected to the motherboard.
    • This replacement will require a soldering station.
    • To find out more on soldering refer to the Soldering and Desolder page to help you through this process.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 314
