Saltar al contenido principal
Electrohome EAAC475 Speaker Replacement
Qué necesitas
  1. Electrohome EAAC475 Speaker Replacement, Battery: paso 1, imagen 1 de 2 Electrohome EAAC475 Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Speaker Replacement, Buttons: paso 3, imagen 1 de 2 Electrohome EAAC475 Speaker Replacement, Buttons: paso 3, imagen 2 de 2
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 Speaker Replacement: paso 4, imagen 1 de 3 Electrohome EAAC475 Speaker Replacement: paso 4, imagen 2 de 3 Electrohome EAAC475 Speaker Replacement: paso 4, imagen 3 de 3
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 Speaker Replacement: paso 5, imagen 1 de 2 Electrohome EAAC475 Speaker Replacement: paso 5, imagen 2 de 2
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
  6. Electrohome EAAC475 Speaker Replacement, Speaker: paso 6, imagen 1 de 2 Electrohome EAAC475 Speaker Replacement, Speaker: paso 6, imagen 2 de 2
    • Carefully and slowly detach one side from another.
    • Make sure the opposite sides are not separated completely.
    • Locate the speaker the inside of the back piece of the device
  7. Electrohome EAAC475 Speaker Replacement: paso 7, imagen 1 de 1
    • Use the flat side of the spudger to remove the glue around the speaker.
    • This glue will need replacing when putting back the speaker.
  8. Electrohome EAAC475 Speaker Replacement: paso 8, imagen 1 de 1
    • After removing all the glue around the speaker, slowly take out the speaker.
    • Be careful not to break anything surrounding the speaker while using the spudger since it is sharp.
  9. Electrohome EAAC475 Speaker Replacement: paso 9, imagen 1 de 1
    • Detach the wires on the speaker and replace them with new ones.
Conclusión
Ruolin Cai
Miembro Desde 02/16/16
273 Reputación
2 Guías creadas
Equipo
IUPUI, Team 2-1, Harley Spring 2016 Miembro de IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 385
