Saltar al contenido principal
Electrical Wall Outlet Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Electrical Wall Outlet Replacement, Wall Outlet: paso 1, imagen 1 de 2 Electrical Wall Outlet Replacement, Wall Outlet: paso 1, imagen 2 de 2
    • Turn off electrical power from the breaker by switching off the breaker that is connected to the designated area.
    • Check power by plugging in rechargeable device and check if charging. If not charging, power to the wall is off.
  2. Electrical Wall Outlet Replacement: paso 2, imagen 1 de 1
    • Remove the screw from the outlet plate using a flathead screwdriver.
  3. Electrical Wall Outlet Replacement: paso 3, imagen 1 de 1
    • Remove plate from outlet using a Phillips screwdriver.
  4. Electrical Wall Outlet Replacement: paso 4, imagen 1 de 1
    • Remove screws from outlet that are connected to the wall using a Phillips screwdriver.
  5. Electrical Wall Outlet Replacement: paso 5, imagen 1 de 1
    • Remove wires from outlet by gently pulling them out of the outlet and wall.
  6. Electrical Wall Outlet Replacement: paso 6, imagen 1 de 2 Electrical Wall Outlet Replacement: paso 6, imagen 2 de 2
    • Connect wires to new outlet being sure to connected them to their designated port. They are labeled on the back of the outlet with: neutral, ground and hot.
    • Insert wire into the designated port and tighten with Phillips Screwdriver.
    • Neutral Wire- White
    • Ground Wire- Copper
    • Hot Wire- Black
  7. Electrical Wall Outlet Replacement: paso 7, imagen 1 de 3 Electrical Wall Outlet Replacement: paso 7, imagen 2 de 3 Electrical Wall Outlet Replacement: paso 7, imagen 3 de 3
    • Reassemble the outlet as it was removed.
Conclusión
5 personas más completaron esta guía.
Equipo
Texas Tech, Team 22-4, Rauch Spring 2016 Miembro de Texas Tech, Team 22-4, Rauch Spring 2016
TTU-RAUCH-S16S22G4
2 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 1,219
