Saltar al contenido principal
Electric Wheelchair Battery Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
  1. Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: paso 1, imagen 1 de 3 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: paso 1, imagen 2 de 3 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: paso 1, imagen 3 de 3
    • Locate the two batteries under the back of the wheelchair.
    • Pull the first battery pack to where you can reach the red battery connector.
    • Be careful, the batteries are heavy.
  2. Electric Wheelchair Battery Replacement: paso 2, imagen 1 de 2 Electric Wheelchair Battery Replacement: paso 2, imagen 2 de 2
    • Disconnect the red battery connectors by pulling them apart.
  3. Electric Wheelchair Battery Replacement: paso 3, imagen 1 de 2 Electric Wheelchair Battery Replacement: paso 3, imagen 2 de 2
    • Remove the first and second battery from the wheelchair.
  4. Electric Wheelchair Battery Replacement: paso 4, imagen 1 de 2 Electric Wheelchair Battery Replacement: paso 4, imagen 2 de 2
    • Disconnect the black battery connectors by pulling them apart.
  5. Electric Wheelchair Battery Replacement: paso 5, imagen 1 de 3 Electric Wheelchair Battery Replacement: paso 5, imagen 2 de 3 Electric Wheelchair Battery Replacement: paso 5, imagen 3 de 3
    • One at a time, disconnect the clips holding each battery case closed.
    • Open each case to reveal the battery inside.
  6. Electric Wheelchair Battery Replacement: paso 6, imagen 1 de 3 Electric Wheelchair Battery Replacement: paso 6, imagen 2 de 3 Electric Wheelchair Battery Replacement: paso 6, imagen 3 de 3
    • Remove the old battery from each case.
    • Put one new battery into each plastic case the old batteries were removed from.
  7. Electric Wheelchair Battery Replacement: paso 7, imagen 1 de 1
    • Reattach the clips on each of the battery's protective casings.
  8. Electric Wheelchair Battery Replacement: paso 8, imagen 1 de 3 Electric Wheelchair Battery Replacement: paso 8, imagen 2 de 3 Electric Wheelchair Battery Replacement: paso 8, imagen 3 de 3
    • Place the first battery back into the holder under the wheelchair.
    • Make sure that it is pushed all the way to the front of the wheelchair.
    • Place the second battery back into the holder.
  9. Electric Wheelchair Battery Replacement: paso 9, imagen 1 de 3 Electric Wheelchair Battery Replacement: paso 9, imagen 2 de 3 Electric Wheelchair Battery Replacement: paso 9, imagen 3 de 3
    • Reconnect the black battery connectors.
    • Do not connect the red connectors until the black are connected.
    • Reconnect the red battery connectors.
    • Check that the chair turns on and is fully charged.
Linea de Meta
3 personas más completaron esta guía.
Paige Efting
Miembro Desde 01/19/16
159 Reputación
1 Guía escrita
Equipo
1Guía Comentario
I greatly enjoyed reading your article :) Please continue publishing helpful topics like this. Regards, from <a href="http://www.scootersnchairs.com">Scooters 'N Chairs</a>.
Justin Lubomirsky - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 75
Todo El Tiempo: 7,413
