Introducción
This guide will show you how to replace a broken or cracked screen on your tablet.
Qué necesitas
Power down your device.
Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
To reassemble your device, apply glue to the screen and press it to the LCD, then follow these instructions in reverse order.
