Introducción
The LED Chip is responsible for the rear camera flash and flashlight functions. This is a guide to replacing the chip with a new one, if the current one in your device is malfunctioning.
NOTE: You may omit step six of this guide, removing the battery.
Herramientas
Partes
No se especificaron partes.
Power down your device.
Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
With a Phillips #00 screwdriver, remove the one 3.8 mm screw in the LED chip. The LED chip is a small green chip (about 1 square centimeter) located at the top center of the device.
Gently remove the chip with a pair of precision tweezers by grabbing the chip from one side, being careful not to pinch on a black piece of hardware on the chip.
