Saltar al contenido principal
Ecovacs Deebot 900 Motherboard Replacement
Qué necesitas
  1. Ecovacs Deebot 900 Motherboard Replacement, Front Bumper: paso 1, imagen 1 de 2 Ecovacs Deebot 900 Motherboard Replacement, Front Bumper: paso 1, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  2. Ecovacs Deebot 900 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the black strip on the bottom of the bumper.
  3. Ecovacs Deebot 900 Motherboard Replacement: paso 3, imagen 1 de 2 Ecovacs Deebot 900 Motherboard Replacement: paso 3, imagen 2 de 2
    • Carefully lift up the bumper untill it pops out of place.​
  4. Ecovacs Deebot 900 Motherboard Replacement: paso 4, imagen 1 de 2 Ecovacs Deebot 900 Motherboard Replacement: paso 4, imagen 2 de 2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  5. Ecovacs Deebot 900 Motherboard Replacement, Bottom Case: paso 5, imagen 1 de 2 Ecovacs Deebot 900 Motherboard Replacement, Bottom Case: paso 5, imagen 2 de 2
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  6. Ecovacs Deebot 900 Motherboard Replacement: paso 6, imagen 1 de 2 Ecovacs Deebot 900 Motherboard Replacement: paso 6, imagen 2 de 2
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
  7. Ecovacs Deebot 900 Motherboard Replacement, Motherboard: paso 7, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
  8. Ecovacs Deebot 900 Motherboard Replacement: paso 8, imagen 1 de 1
    • Carefully remove the ribbon cables connected to the top of motherboard.
    • Keep track of where the cables connect to the motherboard.
  9. Ecovacs Deebot 900 Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the last three ribbon cables on the underside of the motherboard.​
  10. Ecovacs Deebot 900 Motherboard Replacement: paso 10, imagen 1 de 1
    • Lift the motherboard out of the Deebot and remove it from the device.
Conclusión
6 personas más completaron esta guía.
3 comentarios
Any suggestions on purchase options?
Curtis Tyler - Contestar
vakum ozmo 900,hidup terus mati,lampu led juga mati,switch masih posisi on
markus arif - Contestar
If anyone is keen to see how to replace a motherboard on the Ecovacs Deebot Ozmo 950 (same for T5), here's a video guide on how I did it: https://youtu.be/jlsOlYYFl8k. If the link doesn't work, search YouTube for "Ecovacs Deebot 950 Stopped Working! How to replace MOTHERBOARD and make it work again!!". The motherboard replacement cost me $90 AUD from AliExpress. Basically, my Deebot 950 was no longer charging despite me installing a new battery replacement, and when I'd turn on the robot, it would back out of the charging dock and then simply turn off (deactivate), and there was nothing I could do. The motherboard is the problem. I replaced it myself and now it works like brand new again. Hopefully my video guide helps others. I was literally on the verge of throwing this cleaner into the rubbish thinking it no longer works.... but gave it one last attempt to fix and glad I did! :)
Jel Builder - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 39
Ultimos 30 días: 125
Todo El Tiempo: 8,604
