Saltar al contenido principal
Ecovacs Deebot 900 Battery Replacement
Qué necesitas
  1. Ecovacs Deebot 900 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Battery Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Battery Replacement: paso 4, imagen 1 de 1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Battery Replacement: paso 5, imagen 1 de 1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
Conclusión
5 personas más completaron esta guía.
5 comentarios
Great guide except no information on where to actually FIND a battery for this thing
Chris Staley - Contestar
Where can replacement battery packs be acquired from?
Larry Smith - Contestar
You can find the battery at Taobao online shopping
Jimmy - Contestar
Amazon also sells them. Make sure to get one for the correct model though (there are alot of them)
Kevin Dunn - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 105
Ultimos 30 días: 485
Todo El Tiempo: 21,660
