Saltar al contenido principal
Introducción
This guide will show you how to remove a defective vacuum motor on the Ecovacs DEEBOT D35. To replace it, install a new one by follow these steps in reverse.
Partes
No se especificaron partes.
  1. Ecovacs DEEBOT D35 Vacuum Motor Replacement, Vacuum Motor: paso 1, imagen 1 de 1
    • Lay the Deebot face down so you have access to the battery compartment. Remove the battery.
  2. Ecovacs DEEBOT D35 Vacuum Motor Replacement: paso 2, imagen 1 de 1
    • Locate the 9 screws that secure the back cover. Remove with a PH2 Phillips Head Screwdriver. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Vacuum Motor Replacement: paso 3, imagen 1 de 1
    • Use a spudger or plastic opening tool to separate the Deebot backside.
  4. Ecovacs DEEBOT D35 Vacuum Motor Replacement: paso 4, imagen 1 de 1
    • Carefully lift the back cover from the body of the Deebot to expose the internal wiring harnesses.
  5. Ecovacs DEEBOT D35 Vacuum Motor Replacement: paso 5, imagen 1 de 1
    • There are 5 wiring harnesses that need to be disconnected before completely removing the back cover.
    • There are two blue wiring harnesses on the front left and right side (located next to the sensor). They are represented by the red circles.
    • There is a multicolor wiring harness on the front center. This is represented by the orange circle.
    • Two black and red wiring harnesses are connected to the motherboard. This is represented by the yellow circles.
  6. Ecovacs DEEBOT D35 Vacuum Motor Replacement: paso 6, imagen 1 de 1
    • Locate the 4 screws on the vacuum motor.
  7. Ecovacs DEEBOT D35 Vacuum Motor Replacement: paso 7, imagen 1 de 1
    • Remove the screws from the vacuum motor body with a PH2 Phillips Head Screwdriver. The screws are:
    • 4 x 10mm screws
  8. Ecovacs DEEBOT D35 Vacuum Motor Replacement: paso 8, imagen 1 de 1
    • Remove the vacuum motor body
Conclusión
3 personas más completaron esta guía.
Brian
Miembro Desde 15/02/17
475 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 12-2, Eyestone Spring 2017 Miembro de USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
4 Miembros
4 Guías creadas
Un comentario
thanks a lots for the valuable info
sk law - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 17
Ultimos 30 días: 99
Todo El Tiempo: 8,189
