Saltar al contenido principal
Ecovacs DEEBOT D35 Motherboard Replacement
Qué necesitas
  1. Ecovacs DEEBOT D35 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Flip the D35 onto its back.
  2. Ecovacs DEEBOT D35 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the 9 screws with a PH2 Phillips screwdriver on the underside of the D35. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Motherboard Replacement: paso 3, imagen 1 de 1
    • Use spudger or plastic opening tool to separate the Deebot backside
  4. Ecovacs DEEBOT D35 Motherboard Replacement: paso 4, imagen 1 de 1
    • Carefully lift the back cover from the body of the Deebot
  5. Ecovacs DEEBOT D35 Motherboard Replacement: paso 5, imagen 1 de 2 Ecovacs DEEBOT D35 Motherboard Replacement: paso 5, imagen 2 de 2
    • There are 5 cables that need to be carefully disconnected before completely disconnecting the back cover:
    • The 5 cables two blue cables on the front left and right side (located next to the sensor). Represented by the red arrows.
    • Multicolor ribbon in the front center. Represented by the blue arrow.
    • Two (black and red) two prong adapter connected to the motherboard. Represented by the green arrow.
  6. Ecovacs DEEBOT D35 Motherboard Replacement: paso 6, imagen 1 de 3 Ecovacs DEEBOT D35 Motherboard Replacement: paso 6, imagen 2 de 3 Ecovacs DEEBOT D35 Motherboard Replacement: paso 6, imagen 3 de 3
    • Locate the 3 screws on the motherboard:
    • 2 x 14mm screws
    • 1 x 10mm screws
  7. Ecovacs DEEBOT D35 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the screws from the motherboard with a PH2 Phillips Head Screwdriver. The screws are:
    • 2 x 14mm screws
    • 1 x 10mm screws
  8. Ecovacs DEEBOT D35 Motherboard Replacement: paso 8, imagen 1 de 2 Ecovacs DEEBOT D35 Motherboard Replacement: paso 8, imagen 2 de 2
    • Locate and disconnect 12 cables bundles connected on the motherboard
  9. Ecovacs DEEBOT D35 Motherboard Replacement: paso 9, imagen 1 de 1
    • Carefully disconnect the motherboard from the Deebot body.
Conclusión
2 personas más completaron esta guía.
Kevin McKernan
Miembro Desde 02/15/17
107 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 12-2, Eyestone Spring 2017 Miembro de USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 13
Todo El Tiempo: 2,715
