Saltar al contenido principal
Ecovacs DEEBOT D35 Battery Replacement
Qué necesitas
  1. Ecovacs DEEBOT D35 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Press and hold the tabs on both sides of the battery.
  2. Ecovacs DEEBOT D35 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the Deebot
  3. Ecovacs DEEBOT D35 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the screw attaching the battery housing.
  4. Ecovacs DEEBOT D35 Battery Replacement: paso 4, imagen 1 de 1
    • Inert the new battery casing into the housing.
    • Replace the screw attaching the housing.
    • Replace the batter housing in the Deebot.
Conclusión
3 personas más completaron esta guía.
Brian
Miembro Desde 02/15/17
475 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 12-2, Eyestone Spring 2017 Miembro de USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
4 Miembros
4 Guías creadas
7 comentarios
How do you actually take the battery pack out of the casing?
Jonathan A - Contestar
Where can i find a replacement battery for deebot model d35
Travis neas - Contestar
JonathanA - you don't, it comes complete in the casing and can not be opened.
Kate Oe - Contestar
But where can we buy a replacement battery for deebot 35?
Kay Pott - Contestar
Where can i buy a replacement battery for D35
Terry Martin
Terry Martin -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 58
Todo El Tiempo: 13,964
