Saltar al contenido principal
Eco X Gear Voice Coil Replacement
Qué necesitas
  1. Eco X Gear Voice Coil Replacement, Frame: paso 1, imagen 1 de 1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Voice Coil Replacement: paso 2, imagen 1 de 1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Voice Coil Replacement: paso 3, imagen 1 de 1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Voice Coil Replacement: paso 4, imagen 1 de 1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Voice Coil Replacement, Voice Coil: paso 5, imagen 1 de 1
    • Disconnect the wiring to improve accessibility to the cones.
  6. Eco X Gear Voice Coil Replacement: paso 6, imagen 1 de 2 Eco X Gear Voice Coil Replacement: paso 6, imagen 2 de 2
    • Remove the four screws that hold down the speaker and pry up the speaker from the frame.
  7. Eco X Gear Voice Coil Replacement: paso 7, imagen 1 de 1
    • Once the voice coil is removed, solder it back onto the bracket or replace the voice coil entirely.
Conclusión
James Lipsett
Miembro Desde 03/20/17
625 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 193
