Saltar al contenido principal
Eco X Gear Battery Replacement
Qué necesitas
  1. Eco X Gear Battery Replacement, Frame: paso 1, imagen 1 de 1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Battery Replacement: paso 2, imagen 1 de 1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Battery Replacement: paso 3, imagen 1 de 1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Battery Replacement: paso 4, imagen 1 de 1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Battery Replacement, Battery: paso 5, imagen 1 de 1
    • Disconnect the wiring to improve accessibility to the battery.
  6. Eco X Gear Battery Replacement: paso 6, imagen 1 de 2 Eco X Gear Battery Replacement: paso 6, imagen 2 de 2
    • Remove the two screws that hold that bracket, securing the battery in place.
  7. Eco X Gear Battery Replacement: paso 7, imagen 1 de 1
    • Disconnect the wires that hold the batteries down to the motherboard.
  8. Eco X Gear Battery Replacement: paso 8, imagen 1 de 1
    • Pry the battery from the frame using your hands or an opening pick.
  9. Eco X Gear Battery Replacement: paso 9, imagen 1 de 1
    • When removing and installing the battery, be cautious to not damage any of the surrounding electronics.
Conclusión
Una persona más ha completado esta guía.
James Lipsett
Miembro Desde 03/20/17
625 Reputación
6 Guías creadas
Equipo
3 comentarios
Where to get the new battery?
James Chen - Contestar
Hello EcoXGear lovers, i just bought this battery from amazon yesterday and perfect fit with polarity you can get the battery here
https://www.amazon.com/gp/product/B08ZCQ...
partha - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 36
Todo El Tiempo: 720
