Saltar al contenido principal
Eclipse MTE28VGM Toggle Button Replacement
Qué necesitas
  1. Eclipse MTE28VGM Toggle Button Replacement, Toggle Button: paso 1, imagen 1 de 3 Eclipse MTE28VGM Toggle Button Replacement, Toggle Button: paso 1, imagen 2 de 3 Eclipse MTE28VGM Toggle Button Replacement, Toggle Button: paso 1, imagen 3 de 3
    • Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
    • Use caution when removing the screws as they can strip easily.
  2. Eclipse MTE28VGM Toggle Button Replacement: paso 2, imagen 1 de 3 Eclipse MTE28VGM Toggle Button Replacement: paso 2, imagen 2 de 3 Eclipse MTE28VGM Toggle Button Replacement: paso 2, imagen 3 de 3
    • Using the small metal pry bar, remove the bottom plastic cover.
    • Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart
    • On occasion the battery can become swollen and make this process difficult. You might need to use the spudger to push on the bottom components to assist in the separation.
  3. Eclipse MTE28VGM Toggle Button Replacement: paso 3, imagen 1 de 3 Eclipse MTE28VGM Toggle Button Replacement: paso 3, imagen 2 de 3 Eclipse MTE28VGM Toggle Button Replacement: paso 3, imagen 3 de 3
    • Using the screwdriver, remove the four 4.8 mm Phillips head J00 screws at each corner of the motherboard.
    • Remove the motherboard from the front plastic cover and screen. Replace the old motherboard with the new motherboard.
  4. Eclipse MTE28VGM Toggle Button Replacement: paso 4, imagen 1 de 3 Eclipse MTE28VGM Toggle Button Replacement: paso 4, imagen 2 de 3 Eclipse MTE28VGM Toggle Button Replacement: paso 4, imagen 3 de 3
    • Use the angled tweezers to disconnect the toggle button covering.
  5. Eclipse MTE28VGM Toggle Button Replacement: paso 5, imagen 1 de 1
    • Using the angled tweezers, disconnect the toggle button.
Conclusión
Tyler Hudgens
Miembro Desde 09/29/16
288 Reputación
2 Guías creadas
Equipo
IUPUI, Team 2-1, Harley Fall 2016 Miembro de IUPUI, Team 2-1, Harley Fall 2016
IUPUI-HARLEY-F16S2G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 117
