Introducción
This guide will provide you with the necessary steps and tools required to completely disassemble the Eclipse MTE28VGM and replace the motherboard. In order to perform any replacements, knowledge of how to disassemble the device must be done first. Also, it is possible after disassembly of the device for the battery to swell.
Qué necesitas
Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
Casi Terminas!
Linea de Meta
