Saltar al contenido principal
Eclipse 180G2 MP3 Video Player speaker Replacement
Qué necesitas
  1. Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: paso 1, imagen 1 de 2 Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: paso 1, imagen 2 de 2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: paso 2, imagen 1 de 3 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: paso 2, imagen 2 de 3 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: paso 2, imagen 3 de 3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
  3. Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: paso 3, imagen 1 de 2 Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: paso 3, imagen 2 de 2
    • Identify the speaker. Pull the speaker away from the device so that wires are exposed.
    • Using a wire cutter, sever the red and black cables that are connecting the speaker to the circuit board.
    • You will need to solder the new speaker wires to connect it to the device.
Conclusión
  • To reassemble your device after completion of replacement, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Jesse Minor
Miembro Desde 01/15/15
662 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-4, Tanski Winter 2015 Miembro de USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 19
Todo El Tiempo: 890
