Saltar al contenido principal
Eclipse 180G2 MP3 Video Player Buttons Replacement
Qué necesitas
  1. Eclipse 180G2 MP3 Video Player Buttons Replacement, Outer Case: paso 1, imagen 1 de 2 Eclipse 180G2 MP3 Video Player Buttons Replacement, Outer Case: paso 1, imagen 2 de 2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 MP3 Video Player Buttons Replacement, Remove inner circuit from case shell: paso 2, imagen 1 de 3 Eclipse 180G2 MP3 Video Player Buttons Replacement, Remove inner circuit from case shell: paso 2, imagen 2 de 3 Eclipse 180G2 MP3 Video Player Buttons Replacement, Remove inner circuit from case shell: paso 2, imagen 3 de 3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
  3. Eclipse 180G2 MP3 Video Player Buttons Replacement, Removing the Screen: paso 3, imagen 1 de 1
    • Freed from the internal space of the device, the LCD screen as well as the buttons will simply fall out of the face of the device. They can now easily be replaced.
Conclusión
Una persona más ha completado esta guía.
James Walker
Miembro Desde 01/15/15
373 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-4, Tanski Winter 2015 Miembro de USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 1,332
