Saltar al contenido principal
Eclipse 180BL Touch Pad Replacement
Qué necesitas
  1. Eclipse 180BL Touch Pad  Replacement, Touch Pad: paso 1, imagen 1 de 1
    • Remove the two screws at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair toolkit.
    • The two screws are 1/8 inch in length.
    • Remove the cover to reveal the internal component.
  2. Eclipse 180BL Touch Pad  Replacement: paso 2, imagen 1 de 3 Eclipse 180BL Touch Pad  Replacement: paso 2, imagen 2 de 3 Eclipse 180BL Touch Pad  Replacement: paso 2, imagen 3 de 3
    • Using the Spudger, forcefully push upward on the USB port of the device to remove the main component.
    • This will release the tension on the multiple parts. One of which will be the touch pad.
    • The touch pad can now be easily replaced.
    • The touch pad has a smaller center piece that must be replaced for proper usage of the device.
Conclusión
Una persona más ha completado esta guía.
Thomas Schwarz
Miembro Desde 09/07/15
499 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 640
