Saltar al contenido principal
Eclipse 180BL LCD Screen Cover Replacement
Qué necesitas
  1. Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: paso 1, imagen 1 de 3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: paso 1, imagen 2 de 3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: paso 1, imagen 3 de 3
    • To start, remove the two screws located at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair ToolKit.
    • Both Screws are 1/8 inch in length.
    • Remove the case, and with the Spudger, apply force to the USB port to remove the inner component.
    • Be careful, as releasing the tension will cause all parts to become loose and separate.
  2. Eclipse 180BL LCD Screen Cover Replacement: paso 2, imagen 1 de 3 Eclipse 180BL LCD Screen Cover Replacement: paso 2, imagen 2 de 3 Eclipse 180BL LCD Screen Cover Replacement: paso 2, imagen 3 de 3
    • The LCD screen cover is placed into its slot after all the inner components are replaced.
    • Get the new screen cover, and carefully place in alignment with the outer shell.
    • Be sure that the screen fits perfectly, as dust getting in the screen will cause pixels to die.
Conclusión
Thomas Schwarz
Miembro Desde 09/07/15
499 Reputación
3 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 724
