Saltar al contenido principal
Eclipse 180BL Battery Replacement
Qué necesitas
  1. Eclipse 180BL Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the two screws located on the bottom of the device with a phillips head screw driver.
    • The two screws can be removed using the PH00 head from the iFixit repair toolkit.
    • Both screws are 1/8 inch in length.
    • The bottom cap will come off to reveal the inside main component.
  2. Eclipse 180BL Battery Replacement: paso 2, imagen 1 de 2 Eclipse 180BL Battery Replacement: paso 2, imagen 2 de 2
    • Remove the main inner component using Spudger, by pushing on the USB port. This will take some force.
    • Hold on the sides with your fingers, and push to release from the top.
  3. Eclipse 180BL Battery Replacement: paso 3, imagen 1 de 3 Eclipse 180BL Battery Replacement: paso 3, imagen 2 de 3 Eclipse 180BL Battery Replacement: paso 3, imagen 3 de 3
    • The plastic LCD cover and the key pad will now be loose; they were held in place by the tension between the case and the internal main component.
    • Locate the large square pack with a black and red wire coming out of it, this is the battery.
    • Cut the red and black wires to remove the old battery.
  4. Eclipse 180BL Battery Replacement: paso 4, imagen 1 de 1
    • To Replace, connect the two new lines ( red and black) between the new battery and the device.
    • You have successfully replaced the battery!
Conclusión
3 personas más completaron esta guía.
Thomas Schwarz
Miembro Desde 09/07/15
499 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 25
Todo El Tiempo: 1,357
