Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Eatsmart ESBS-01 Battery Replacement
  1. Eatsmart ESBS-01 Battery Replacement, Battery: paso 1, imagen 1 de 2 Eatsmart ESBS-01 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • The LO message on the screen indicates that your digital weight scale is running on low battery so you need to get the replacement battery.
    • This area is where the batteries located, top right corner of the scale.
  2. Eatsmart ESBS-01 Battery Replacement: paso 2, imagen 1 de 2 Eatsmart ESBS-01 Battery Replacement: paso 2, imagen 2 de 2
    • To open the battery compartment, use your finger to gentling push the tip to open the battery compartment.
  3. Eatsmart ESBS-01 Battery Replacement: paso 3, imagen 1 de 2 Eatsmart ESBS-01 Battery Replacement: paso 3, imagen 2 de 2
    • Remove the old batteries from the device by pushing the battery toward the wire side and gentling taking it out.
  4. Eatsmart ESBS-01 Battery Replacement: paso 4, imagen 1 de 2 Eatsmart ESBS-01 Battery Replacement: paso 4, imagen 2 de 2
    • Insert the new batteries in the device.
    • Be aware to place the batteries in the right charge. The positive (+) and negative (-) signs are labeled inside the battery compartment. Place the flat side of the battery to the negative side and the little lip side of the battery to the positive side on the device.
  5. Eatsmart ESBS-01 Battery Replacement: paso 5, imagen 1 de 3 Eatsmart ESBS-01 Battery Replacement: paso 5, imagen 2 de 3 Eatsmart ESBS-01 Battery Replacement: paso 5, imagen 3 de 3
    • Put the cover of the compartment back. You successfully replaced the batteries.
    • You should now see the weight displaying on the screen after the replacement.
Conclusión
Una persona más ha completado esta guía.
Elle Luo
Miembro Desde 04/28/17
137 Reputación
1 Guía escrita
Equipo
UC Davis, Team S4-G1, Cole Spring 2017 Miembro de UC Davis, Team S4-G1, Cole Spring 2017
UCD-COLE-S17S4G1
Miembros de 3
3 Guías creadas
1Guía Comentario
I changed to new four AAA batteries, however, the LCD remained blank after very brief purple color. What can be done?
Jay Patel - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 52
Todo El Tiempo: 2,638
