Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
EBK340 Powerhead Replacement
Qué necesitas
  1. EBK340  Powerhead  Replacement, Remove Outer Cover: paso 1, imagen 1 de 1
    • Position the device so brushes are upwards and visible
    • Unscrew the 6 outer screws. 2 on the edge of the brush crevice, and 4 nearer to the wheels.
    • Turn over the device.
    • Pull the cover off gently.
    Pregunta a FixBot
  2. EBK340  Powerhead  Replacement, Remove Inner Cover: paso 2, imagen 1 de 1
    • Unscrew the 2 screws indicated, one visible, the other within a deep hole
    • Gently pull off the cover. Careful not to torque the plastic teeth shown in orange.
    Pregunta a FixBot
  3. EBK340  Powerhead  Replacement, Replace Neck Joint: paso 3, imagen 1 de 2 EBK340  Powerhead  Replacement, Replace Neck Joint: paso 3, imagen 2 de 2
    • Gently lift the two LED lights upwards and away for the moment.
    • Gently lift out the defective neck joint.
    • Slide in the replacement joint.
    • Replace the lights into the molded corners that hold their board.
    Pregunta a FixBot
Conclusión
Una persona más ha completado esta guía.
FolsomMaids Office
Miembro Desde 10/09/19
167 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 270
