Saltar al contenido principal
E-Cigarette Vaporizer Coil Replacement
Qué necesitas
  1. E-Cigarette Vaporizer Coil Replacement, Coil: paso 1, imagen 1 de 2 E-Cigarette Vaporizer Coil Replacement, Coil: paso 1, imagen 2 de 2
    • Pull up to remove the top cap from the IPV Mini II.
    • The unit may have hot surfaces.
    • Allow components to cool before starting.
  2. E-Cigarette Vaporizer Coil Replacement: paso 2, imagen 1 de 1
    • Using a Phillips head screwdriver, turn counter clockwise to loosen the positive and negative screws.
    • Be sure that the IPV Mini II is powered off before proceeding.
  3. E-Cigarette Vaporizer Coil Replacement: paso 3, imagen 1 de 1
    • Gently remove the burnt coil from the positive and negative screws.
  4. E-Cigarette Vaporizer Coil Replacement: paso 4, imagen 1 de 1
    • Place the new coil into the holes underneath the positive and negative screws.
  5. E-Cigarette Vaporizer Coil Replacement: paso 5, imagen 1 de 1
    • Using a Phillips screwdriver, gently turn clockwise to tighten down the positive and negative screws onto the coil.
  6. E-Cigarette Vaporizer Coil Replacement: paso 6, imagen 1 de 2 E-Cigarette Vaporizer Coil Replacement: paso 6, imagen 2 de 2
    • Replace the top cap onto the IPV Mini II.
Conclusión
To reverse the process, simply follow the instructions in reverse.
For more information visit https://bevapehappy.com/
12 personas más completaron esta guía.
rzgraves
Miembro Desde 07/16/15
624 Reputación
1 Guía escrita
Equipo
Texas Tech, Team 3-4, Rauch SU 2015 Miembro de Texas Tech, Team 3-4, Rauch SU 2015
TTU-RAUCH-SU15S3G4
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 52
Todo El Tiempo: 5,202
