Saltar al contenido principal
Introducción
If there are issues with the suction of the Dyson v6 Absolute, the cyclone may have to be cleaned or replaced.
  1. Unplug the device.
    • Unplug the device.
  2. Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
    • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
    • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
  3. Push the red lever down a second time to release the debris bin.
    • Push the red lever down a second time to release the debris bin.
  4. Pull bin away from the cyclone.
    • Pull bin away from the cyclone.
  5. Separate the bin from the main body of the device.
    • Separate the bin from the main body of the device.
  6. Locate two visible white clips between the main body and the cyclone.
    • Locate two visible white clips between the main body and the cyclone.
  7. Use tweezers to pinch the white clips together.
    • Use tweezers to pinch the white clips together.
    • Widely hold the tweezers apart to get them to reach between the two white clips.
    • Because the space is tight between the cyclone and the main body, pinching the white clips may require additional effort.
  8. Tilt and pull the main body away from the cyclone. There may be a loud snap when the main body separates from the cyclone.
    • Tilt and pull the main body away from the cyclone.
    • There may be a loud snap when the main body separates from the cyclone.
  9. Use the spudger to remove the cyclone.
    • Use the spudger to remove the cyclone.
    • Start at the small opening beneath the place where the cyclone connects to the main body.
    • Work the spudger around the rim of the red screen filter.
    • You will hear popping noises.
  10. Use a T9 Torx screwdriver to remove five 14mm screws from the edge of the screen filter body. Use a T9 Torx screwdriver to remove five 14mm screws from the edge of the screen filter body.
    • Use a T9 Torx screwdriver to remove five 14mm screws from the edge of the screen filter body.
  11. Remove the filter screen cover away from the cyclone.
    • Remove the filter screen cover away from the cyclone.
    • Pull down on the black tube inside the cyclone body to remove it from the cyclone.
Conclusión
12 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 48
Ultimos 30 días: 182
Todo El Tiempo: 14,399
