Saltar al contenido principal
Dyson V6 Motorhead Motor Replacement
Qué necesitas
  1. Dyson V6 Motorhead Motor Replacement, Collection Bin: paso 1, imagen 1 de 2 Dyson V6 Motorhead Motor Replacement, Collection Bin: paso 1, imagen 2 de 2
    • Pull down on the red release tab.
    • When the tab is fully engaged, the bottom of the bin should open.
  2. Dyson V6 Motorhead Motor Replacement: paso 2, imagen 1 de 2 Dyson V6 Motorhead Motor Replacement: paso 2, imagen 2 de 2
    • Pull down on the release tab a second time, this time the collection bin should release from the upper vacuum head.
  3. Dyson V6 Motorhead Motor Replacement: paso 3, imagen 1 de 3 Dyson V6 Motorhead Motor Replacement: paso 3, imagen 2 de 3 Dyson V6 Motorhead Motor Replacement: paso 3, imagen 3 de 3
    • Pull the collection bin away from the upper vacuum head.
  4. Dyson V6 Motorhead Motor Replacement, Motor: paso 4, imagen 1 de 1
    • Identify the two white components between the vacuum handle and the attached component.
  5. Dyson V6 Motorhead Motor Replacement: paso 5, imagen 1 de 2 Dyson V6 Motorhead Motor Replacement: paso 5, imagen 2 de 2
    • Insert each arm of the tweezer into each white component area and squeeze simultaneously to release the motor from the attached component.
  6. Dyson V6 Motorhead Motor Replacement: paso 6, imagen 1 de 2 Dyson V6 Motorhead Motor Replacement: paso 6, imagen 2 de 2
    • Detach the motor from the remaining motor head assembly.
Conclusión
10 personas más completaron esta guía.
Addie Hedge
Miembro Desde 01/24/17
710 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 22-6, Maness Winter 2017 Miembro de Cal Poly, Team 22-6, Maness Winter 2017
CPSU-MANESS-W17S22G6
4 Miembros
5 Guías creadas
3 comentarios
really good can understand and not too technical
kelvin - Contestar
I am terrible at fixing things and this helped me put my vacuum back together after it fell and the motor detached from the handle. Thank you!!!
Chris Tadda - Contestar
Can't see the tweezer being inserted into the white tabs. Picture not clear. Could not dislodge motorhead from cannister bin. Show a clearer picture. Thanks
Hem - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 66
Todo El Tiempo: 18,988
