Saltar al contenido principal
Dyson Supersonic HD03 Hairdryer Filter Replacement
Qué necesitas
  1. Dyson Supersonic HD03 Hairdryer Filter Replacement, Filter: paso 1, imagen 1 de 2 Dyson Supersonic HD03 Hairdryer Filter Replacement, Filter: paso 1, imagen 2 de 2
    • Unplug the hairdryer to avoid further hazard.
  2. Dyson Supersonic HD03 Hairdryer Filter Replacement: paso 2, imagen 1 de 2 Dyson Supersonic HD03 Hairdryer Filter Replacement: paso 2, imagen 2 de 2
    • Remove the dirty filter cage by twisting the filter towards the left.
    • The filter cage will be unlocked when the red dot matches the white thin circle.
    • Do not run your hairdryer without a filter cage.
  3. Dyson Supersonic HD03 Hairdryer Filter Replacement: paso 3, imagen 1 de 1
    • Soak the filter cage in dish soap and warm water for at least 30 minutes.
    • You can leave the filter in for multiple hours or overnight if it's especially dirty.
    • Use the supplied filter cleaning brush or any other cleaning tool to vigorously scrub the soaked filter cage.
    • Be sure to remove all blockages.
  4. Dyson Supersonic HD03 Hairdryer Filter Replacement: paso 5, imagen 1 de 1
    • Rinse and dry your filter cage.
    • Check that the filter cage is clean by holding it up to the light - you should be able to see light through it. If you can't, repeat the previous step.
  5. Dyson Supersonic HD03 Hairdryer Filter Replacement: paso 6, imagen 1 de 2 Dyson Supersonic HD03 Hairdryer Filter Replacement: paso 6, imagen 2 de 2
    • Insert the filter back into the filter cage and install the filter cage back onto the device.
    • The filter cage will be locked when the red dot matches the white filled circle.
Conclusión
Una persona más ha completado esta guía.
Huan-Che Hsu
Miembro Desde 09/18/21
192 Reputación
1 Guía escrita
Equipo
Un comentario
My Dyson hair dryer has quitting every 30 seconds - apparently overheating. It was very easy to remove the filter cage and wipe the filter clean. Problem solved!
Jimjar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 18
Ultimos 30 días: 67
Todo El Tiempo: 4,201
