Saltar al contenido principal
Dyson Supersonic HD01 Filter Mesh Replacement
Qué necesitas
  1. Dyson Supersonic HD01 Filter Mesh Replacement, Unlock the filter cover: paso 1, imagen 1 de 2 Dyson Supersonic HD01 Filter Mesh Replacement, Unlock the filter cover: paso 1, imagen 2 de 2
    • Find the red dot along the top of the filter cover.
    • The red dot will be aligned with the white dot at the bottom of the hair dryer's handle.
    • Twist the filter cover counter-clockwise until the red dot is shifted to align with the white empty circle on the dryer handle.
  2. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter cover: paso 2, imagen 1 de 2 Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter cover: paso 2, imagen 2 de 2
    • Remove the filter cover by sliding it off of the handle.
  3. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the retaining screws: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    T6 Torx Screwdriver
    $9.99
    Comprar
    • Remove the two retaining screws at the base of the handle using a T6 Screwdriver.
  4. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter: paso 4, imagen 1 de 3 Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter: paso 4, imagen 2 de 3 Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter: paso 4, imagen 3 de 3
    • Seperate the filter mesh at the plastic seam by pulling it apart.
    • Remove the filter mesh by sliding it off of the handle.
Conclusión
Una persona más ha completado esta guía.
Ezra Linza
Miembro Desde 09/28/22
115 Reputación
1 Guía escrita
Equipo
4 comentarios
This guide is misleading and obviously trolling. The cable is attached to two ton of power converter bricks there's no way this thing will "slide off" the cable. lol.
gcb - Contestar
The REAL procedure is so complicated, the only REAL tutorial/guide i have found prefers to disassemble the entire device instead of dealing with the power bricks. https://www.youtube.com/watch?v=2XnUlUBZ...
gcb -
slide right off. lol. https://www.youtube.com/watch?v=fsiXJndd... hope you have a saw and several pry tools.
gcb -
updated the guide but i'm not sure how to add steps from another guide (on replacing the motor) up to step 6 only...
gcb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 47
Ultimos 30 días: 219
Todo El Tiempo: 3,686
