Saltar al contenido principal
Dyson DC58 Main Body Replacement
Qué necesitas
Resumen del Video
  1. Dyson DC58 Main Body Replacement, Bin: paso 1, imagen 1 de 1
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Main Body Replacement: paso 2, imagen 1 de 1
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Main Body Replacement: paso 3, imagen 1 de 1
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Main Body Replacement: paso 4, imagen 1 de 2 Dyson DC58 Main Body Replacement: paso 4, imagen 2 de 2
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
  5. Dyson DC58 Main Body Replacement, Main Body: paso 5, imagen 1 de 1
    • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
  6. Dyson DC58 Main Body Replacement: paso 6, imagen 1 de 2 Dyson DC58 Main Body Replacement: paso 6, imagen 2 de 2
    • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
    • Use tweezers to pinch the two visible white clips together.
    • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
  7. Dyson DC58 Main Body Replacement: paso 7, imagen 1 de 1
    • Tilt and pull the main body away from the purple cyclone of the vacuum.
    • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
Conclusión
12 personas más completaron esta guía.
Krista St Onge
Miembro Desde 09/17/15
2,188 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team 2-4, Bruce Fall 2015 Miembro de CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
4 Miembros
19 Guías creadas
4 comentarios
Mine ended up dismantled after it had been dropped. Couldn't get it back together until I read the bit about the tweezers /(pliers) and the white clips. It does not push in with out squeezing them first
Jason - Contestar
Has anyone replaced the red release catch?
chrisashton1 - Contestar
The white C-ring with clips must be pushed down in order to reassemble device. Takes some time to practice.
Anton Simonov - Contestar
I'm trying to figure out how to put spring and plastic pieces back in on the inside of red lever on motor body?? Any help I'd really appreciate ?
t_picano - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 52
Todo El Tiempo: 12,946
