Saltar al contenido principal
Dyson DC56 Motor Replacement
Qué necesitas
  1. Dyson DC56 Motor Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the vacuum is unplugged from charger.
    • Warning: Avoid pressing red trigger because the vacuum will turn on the device and begin suction.
  2. Dyson DC56 Motor Replacement: paso 2, imagen 1 de 1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Motor Replacement: paso 3, imagen 1 de 1
    • Separate the device with the purple button.
  4. Dyson DC56 Motor Replacement: paso 4, imagen 1 de 1
    • Take out the filter.
  5. Dyson DC56 Motor Replacement: paso 5, imagen 1 de 1
    • Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
  6. Dyson DC56 Motor Replacement, Battery screw 2: paso 6, imagen 1 de 1
    • Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
  7. Dyson DC56 Motor Replacement: paso 7, imagen 1 de 1
    • Pull the battery pack down and away from the main body and remove it from the device.
  8. Dyson DC56 Motor Replacement, Motor: paso 8, imagen 1 de 1
    • Take out the 10mm screw using a Phillips #1 screwdriver.
  9. Dyson DC56 Motor Replacement: paso 9, imagen 1 de 1
    • Use a spudger to separate the back plate covering the motor.
    • Be careful when trying to remove the motor with a metal spudger. Be sure your battery is removed before trying to fully remove the motor.
  10. Dyson DC56 Motor Replacement: paso 10, imagen 1 de 1
    • Use a flat spudger to loosen and remove the motor out of the vacuum.
Conclusión
2 personas más completaron esta guía.
John Czerkawski
Miembro Desde 10/02/17
427 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S10-G1, Thompson Fall 2017 Miembro de USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 2,381
