Saltar al contenido principal
Dyson DC56 Cyclone Replacement
Qué necesitas
  1. Dyson DC56 Cyclone Replacement, Dust Bin: paso 1, imagen 1 de 1
    • Make sure the vacuum is unplugged.
    • Warning: Avoid pressing the red trigger because it will turn on and begin suction.
  2. Dyson DC56 Cyclone Replacement: paso 2, imagen 1 de 1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Cyclone Replacement: paso 3, imagen 1 de 1
    • Separate the device with the purple button.
  4. Dyson DC56 Cyclone Replacement: paso 4, imagen 1 de 1
    • Locate the dust bin's red release lever on the side of the device.
    • Make sure if the dust bin is full you open the vacuum over a trash can.
  5. Dyson DC56 Cyclone Replacement: paso 5, imagen 1 de 1
    • Push the red lever to release the dust bin lid.
  6. Dyson DC56 Cyclone Replacement: paso 6, imagen 1 de 1
    • Locate the red lever below the vacuum.
  7. Dyson DC56 Cyclone Replacement: paso 7, imagen 1 de 1
    • Push the red lever, pull the back up and away from the dust bin to separate them.
  8. Dyson DC56 Cyclone Replacement, Cyclone: paso 8, imagen 1 de 1
    • Use a T8-Torque screwdriver to remove the 18mm screw from the back of the Cyclone.
  9. Dyson DC56 Cyclone Replacement: paso 9, imagen 1 de 1
    • Remove the bottom of the cyclone screen by twisting it to the left and pulling down.
  10. Dyson DC56 Cyclone Replacement: paso 10, imagen 1 de 1
    • Remove the rest of the cyclone screen by pulling down.
  11. Dyson DC56 Cyclone Replacement: paso 11, imagen 1 de 1
    • Locate and take out the six 26mm screws with a T-8 Torque screwdriver.
    • Once you have removed the screws you can remove the rest of the Cyclone.
Conclusión
Una persona más ha completado esta guía.
John Czerkawski
Miembro Desde 10/02/17
427 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S10-G1, Thompson Fall 2017 Miembro de USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Miembros
11 Guías creadas
Un comentario
I can’t remove the cyclone screen. Any tricks to removing?
J M - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 948
