Saltar al contenido principal
Dyson DC56 Battery Replacement
Qué necesitas
  1. Dyson DC56 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the vacuum is unplugged from charger.
    • Warning: Avoid pressing red trigger because the vacuum will turn on the device and begin suction.
  2. Dyson DC56 Battery Replacement: paso 2, imagen 1 de 1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Battery Replacement: paso 3, imagen 1 de 1
    • Separate the device with the purple button.
  4. Dyson DC56 Battery Replacement: paso 4, imagen 1 de 1
    • Take out the filter.
  5. Dyson DC56 Battery Replacement: paso 5, imagen 1 de 1
    • Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
  6. Dyson DC56 Battery Replacement, Battery screw 2: paso 6, imagen 1 de 1
    • Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
  7. Dyson DC56 Battery Replacement: paso 7, imagen 1 de 1
    • Pull the battery pack down and away from the main body and remove it from the device.
Conclusión
9 personas más completaron esta guía.
Vu Nguyen
Miembro Desde 10/02/17
189 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S10-G1, Thompson Fall 2017 Miembro de USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Miembros
11 Guías creadas
9 comentarios
Works for the DC44 animal also. :)
Tina Willman-Hammar - Contestar
You left out the removal of the screw above the charging port.
Mike - Contestar
And after unscrewing the 2nd screw, you need very fine tweezers to extract it.
This experience has convinced me never to buy a Dyson product. Their manual gives no info about replacing the battery.
Loohan7 - Contestar
Vu Nguyen and contributors should definitely go back in and REVISE these instructions to include the second screw mentioned by Mike 7/29/18. I almost broke my vacuum because I trust iFixit to vet their content. I discovered the second screw after going to another site and only saw Mike’s post after returning here to see if I missed something - I did: I didn’t read his comments!
Cliff - Contestar
Yikes! Thanks goodness I read the comments before I too almost broke something by not removing the second screw!
Mark Nicoll - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 97
Todo El Tiempo: 9,903
