Saltar al contenido principal
Dyson DC56 Attachments Replacement
Qué necesitas
  1. Dyson DC56 Attachments Replacement, Dust Bin: paso 1, imagen 1 de 1
    • Make sure the vacuum is unplugged.
    • Warning: Avoid pressing the red trigger because it will turn on and begin suction.
  2. Dyson DC56 Attachments Replacement: paso 2, imagen 1 de 1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Attachments Replacement: paso 3, imagen 1 de 1
    • Separate the device with the purple button.
  4. Dyson DC56 Attachments Replacement: paso 4, imagen 1 de 1
    • Locate the dust bin's red release lever on the side of the device.
    • Make sure if the dust bin is full you open the vacuum over a trash can.
  5. Dyson DC56 Attachments Replacement: paso 5, imagen 1 de 1
    • Push the red lever to release the dust bin lid.
  6. Dyson DC56 Attachments Replacement: paso 6, imagen 1 de 1
    • Locate the red lever below the vacuum.
  7. Dyson DC56 Attachments Replacement: paso 7, imagen 1 de 1
    • Push the red lever, pull the back up and away from the dust bin to separate them.
  8. Dyson DC56 Attachments Replacement, Attachments: paso 8, imagen 1 de 1
    • Locate two screws at the back of the attachment holder.
  9. Dyson DC56 Attachments Replacement: paso 9, imagen 1 de 1
    • Use a T8-Torque screwdriver to take out the two 26mm screws out.
  10. Dyson DC56 Attachments Replacement: paso 10, imagen 1 de 1
    • Loosen the attachment holder by using a metal spudger.
  11. Dyson DC56 Attachments Replacement: paso 11, imagen 1 de 1
    • Remove the attachment holder.
Conclusión
John Czerkawski
Miembro Desde 10/02/17
427 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S10-G1, Thompson Fall 2017 Miembro de USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 765
