Saltar al contenido principal
Dyson DC28 Animal Wheel Replacement
Qué necesitas
  1. Dyson DC28 Animal Wheel Replacement, Wheel: paso 1, imagen 1 de 1
    • Flip the vacuum face down with the wheels facing up.
  2. Dyson DC28 Animal Wheel Replacement: paso 2, imagen 1 de 1
    • Start on the right side wheel of the vacuum cleaner
    • Remove the plastic wheel cap by sliding the tip of the metal spudger under the edge of the cap.
    • Gently pry off the plastic cap
  3. Dyson DC28 Animal Wheel Replacement: paso 3, imagen 1 de 3 Dyson DC28 Animal Wheel Replacement: paso 3, imagen 2 de 3 Dyson DC28 Animal Wheel Replacement: paso 3, imagen 3 de 3
    • Identify the e-clip located under the metal axle.
    • The e-clip is very small and may be hard to identify. It is a small metal ring between the metal axle and the plastic wheel.
    • Use the metal spudger to pry off the e-clip.
    • The e-clip is hard to remove and may require extra force.
  4. Dyson DC28 Animal Wheel Replacement: paso 4, imagen 1 de 2 Dyson DC28 Animal Wheel Replacement: paso 4, imagen 2 de 2
    • Slide off the plastic wheel off of the metal axle
    • Be careful when removing plastic wheel. There is a loose metal washer and black axle piston behind the wheel that can easily fall off.
    • Slide off the metal washer and black axle piston from the metal axle
  5. Dyson DC28 Animal Wheel Replacement: paso 5, imagen 1 de 1
    • Remove the metal axle by pulling on the left wheel. This does not take a lot of force and should easily slide out.
    • Repeat steps 2, 3, and 4 to remove the left side wheel from the metal axle.
Conclusión
Zachary Urciuoli
Miembro Desde 01/27/17
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 21-4, Maness Winter 2017 Miembro de Cal Poly, Team 21-4, Maness Winter 2017
CPSU-MANESS-W17S21G4
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 3,019
