Saltar al contenido principal
Dyson DC28 Animal Post/Pre Filter Assemblies Replacement
  1. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement, Post/Pre Filter Assemblies: paso 1, imagen 1 de 1
    • Find and press firmly on the red button located above the dust chamber.
    • Hold the handle and pull away from the vacuum base when the button releases the dust chamber.
    • Set off to the side.
  2. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: paso 2, imagen 1 de 2 Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: paso 2, imagen 2 de 2
    • Find and firmly press the purple buttons on each side of the pre filter assembly.
    • When the button releases the filter and its casing, lift straight out of vacuum base.
    • After removing the filter in its casing, hold the case with one hand while gently prying the filter out with your other hand.
  3. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: paso 3, imagen 1 de 2 Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: paso 3, imagen 2 de 2
    • Find the tab for the post filter cap and pull away from base of vacuum to release the top.
    • When the cap has been swung out of the way, pry the post filter out gently (using same technique as before with pre filter).
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 21-4, Maness Winter 2017 Miembro de Cal Poly, Team 21-4, Maness Winter 2017
CPSU-MANESS-W17S21G4
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 1,932
