Introducción
This guide will take you through the removal of the of the sole plate and the air muscle assembly. The final goal of this guide is to remove and replace the air muscle assembly.
Qué necesitas
Remove the dust collector using the red button located at the top of the bin
Herramienta utilizada en este paso:Metal Spudger$2.99
Use the pointed end of a metal spudger to pull off the e-clip.
Herramienta utilizada en este paso:Flush Cutter$29.99
Use the wire cutters to cut the zip tie holding the tube on.
4 personas más completaron esta guía.
