Introducción
This guide will show you the steps necessary to replace the power cord on your Dyson DC14 vacuum cleaner.
Qué necesitas
Remove the canister from the vacuum.
Disconnect the telescopic vacuum wand.
Remove the two T15 Torx screws securing the switch cover to the vacuum.
Remove the other terminal for the power cord that connects to the terminal below the power switch.
Holding them by their connectors, separate the remaining wire of the power cord from the internal power cable.
16 personas más completaron esta guía.
5 comentarios
What a great site! Easy to follow instructions. My part fit perfectly. I booked marked you site and will be back when necessary. Thank y’all
I was able to remove the terminals from the power cord but am not sure how to remove the connectors from the wires. I am guessing I need to remove these connectors to get the old power cord and then use the connectors with the new wires.
Hello, I have been given a Dyson DC 14 and it looks like the plug has been chopped off clean all the way at the very end of the Court. I would like to replace the plug or the entire cord if that's the case. But I am wondering if I do replace the cord and spend that type of money how do I know if it's going to work or not? So is there a way to test the vacuum with my car battery by touching the two cords to the terminals? also which cord is positive and which cord is negative cuz there's a black and a white cord? I have always wanted a Dyson vacuum. It is actually been a dream of mine because I think they're so cool. So now that I have one I want to fix it as inexpensively as possible. Please help thank you so much Brian Higgins
