Saltar al contenido principal
  1. Take off the dust cannister. Remove the suction hose. Remove the suction hose.
    • Take off the dust cannister.
    • Remove the suction hose.
  2. Extract the front filter. Extract the front filter. Extract the front filter.
    • Extract the front filter.
  3. Extract the rear filter. Unscrew the first Torx screw. Unscrew the first Torx screw.
    • Extract the rear filter.
    • Unscrew the first Torx screw.
  4. Optionally, remove the rear filter cover. Optionally, remove the rear filter cover.
    • Optionally, remove the rear filter cover.
  5. Unscrew the 2nd Torx screw. Disassemble the suction hose connection (optional)
    • Unscrew the 2nd Torx screw.
    • Disassemble the suction hose connection (optional)
  6. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  7. Remove the wheels. The wheels clip onto the body of the appliance. Unscrew the 4 Torx screws (two in the right and two on the left).
    • Remove the wheels.
    • The wheels clip onto the body of the appliance.
    • Unscrew the 4 Torx screws (two in the right and two on the left).
  8. Open the body of the vacuum cleaner. You can use a multimeter to test the switch.
    • Open the body of the vacuum cleaner.
    • You can use a multimeter to test the switch.
    • Disconnect the brown wire at the switch.
    • Disconnect the blue wire at the single connector by the motor.
    • Lift out the motor.
  9. Open the motor housing (4 clips). Remover the motor from its plastic casing.
    • Open the motor housing (4 clips).
    • Remover the motor from its plastic casing.
    • Disconnect the motor.
  10. disassembly of 2 engine coals (1 Phillips screw per coal) disassembly of 2 engine coals (1 Phillips screw per coal) disassembly of 2 engine coals (1 Phillips screw per coal)
    • disassembly of 2 engine coals (1 Phillips screw per coal)
  11. Worn brush. Opening the brush housing. Opening the brush housing.
    • Worn brush.
    • Opening the brush housing.
  12. Extraction of the brush and spring. Extraction of the brush and spring. Extraction of the brush and spring.
    • Extraction of the brush and spring.
  13. Removing the brush. Removing the brush.
    • Removing the brush.
  14. Soldering a new brush. Soldering a new brush.
    • Soldering a new brush.
Conclusión
6 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
christophe
Miembro Desde 14/07/12
590 Reputación
2 Guías creadas
Very useful guide - I treated myself to a new motor as the cost was not much more than the cost of replacement brushes.
Bob - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 24
Últimos 30 Días: 153
Todo El Tiempo: 1,477
