Saltar al contenido principal
Dyson Cyclone V10 Absolute Motor Assembly Replacement
Qué necesitas
  1. Dyson Cyclone V10 Absolute Motor Assembly Replacement, Motor Assembly: paso 1, imagen 1 de 3 Dyson Cyclone V10 Absolute Motor Assembly Replacement, Motor Assembly: paso 1, imagen 2 de 3 Dyson Cyclone V10 Absolute Motor Assembly Replacement, Motor Assembly: paso 1, imagen 3 de 3
    • Remove the extra parts of the vacuum, including the filter and the bin.
    • Press the red arrow under the bin and pull it out.
    • Remove the filter by turning it counterclockwise.
    • Prior to starting the repair, remove the battery.
  2. Dyson Cyclone V10 Absolute Motor Assembly Replacement: paso 2, imagen 1 de 3 Dyson Cyclone V10 Absolute Motor Assembly Replacement: paso 2, imagen 2 de 3 Dyson Cyclone V10 Absolute Motor Assembly Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the one 16.5 mm screw on the back of the handle and two 16.5 mm screws under the battery.
    • Pull the battery downward to remove.
    • If you're just replacing the battery, follow the first two steps in reverse order.
  3. Dyson Cyclone V10 Absolute Motor Assembly Replacement: paso 3, imagen 1 de 2 Dyson Cyclone V10 Absolute Motor Assembly Replacement: paso 3, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the four 16.5 mm screws on the back of the vacuum.
  4. Dyson Cyclone V10 Absolute Motor Assembly Replacement: paso 4, imagen 1 de 2 Dyson Cyclone V10 Absolute Motor Assembly Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 16.5 mm screws under the middle of the vacuum, in front of the handle.
  5. Dyson Cyclone V10 Absolute Motor Assembly Replacement: paso 5, imagen 1 de 2 Dyson Cyclone V10 Absolute Motor Assembly Replacement: paso 5, imagen 2 de 2
    • To separate the body of the vacuum from the motor assembly, gently pull them apart.
Conclusión
3 personas más completaron esta guía.
Kuiyao
Miembro Desde 09/19/22
243 Reputación
1 Guía escrita
Equipo
2 comentarios
Hi I didnt realize u cant vaccum up flour and i vaccumed up quite a bit that spilled. When i went to clean the unit the actual motorhead. After removing the sliding case i stood the motorhead ip and talled the end and all kinds of flour came out the end tube of the motorhead. I kept tapping and more and more flour came out. Is it possible to take apart motorhead or should i take it to repair shop. Please advise
Vicki Benn - Contestar
blow it out with an air compressor to get the flour all out...
Jeremy 888ferris - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 89
Ultimos 30 días: 293
Todo El Tiempo: 4,989
