Saltar al contenido principal
Dyson Cinetic Big Ball Animal Upright Hose Replacement
Qué necesitas
  1. Dyson Cinetic Big Ball Animal Upright Hose Replacement, Hose: paso 1, imagen 1 de 2 Dyson Cinetic Big Ball Animal Upright Hose Replacement, Hose: paso 1, imagen 2 de 2
    • Lift off the dust bin from the Dyson.
  2. Dyson Cinetic Big Ball Animal Upright Hose Replacement: paso 2, imagen 1 de 1
    • Locate the removable hose on the back of the Dyson.
    • Pull up on the hose in order to remove the top half of the hose.
  3. Dyson Cinetic Big Ball Animal Upright Hose Replacement: paso 3, imagen 1 de 1
    • Locate the red tab on the frontside of Dyson.
  4. Dyson Cinetic Big Ball Animal Upright Hose Replacement: paso 4, imagen 1 de 3 Dyson Cinetic Big Ball Animal Upright Hose Replacement: paso 4, imagen 2 de 3 Dyson Cinetic Big Ball Animal Upright Hose Replacement: paso 4, imagen 3 de 3
    • Lift up the red tab with the screwdriver while simultaneously pulling on the back hose.
Conclusión
2 personas más completaron esta guía.
Karla Sunjara
Miembro Desde 01/24/17
891 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S13-G1, Banghart Winter 2017 Miembro de Cal Poly, Team S13-G1, Banghart Winter 2017
CPSU-BANGHART-W17S13G1
3 Miembros
10 Guías creadas
2 comentarios
Following step 4, I tried to “lift” the red tab with my screwdriver. It did not budge. After enlarging the photo, I saw that the tab can be seen from both sides. Therefore, I tried “pushing” the red tab instead of “lifting” it, and it popped right off. “Lifting” and “pushing” are different actions.
vlkea01 - Contestar
I've taken the small hose out (in the picture, it is in the center at the bottom of the balls) now I cannot get it back in - at one point I thought I had it snapped back in but it didn't stay - any ideas?
K BS - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 65
Todo El Tiempo: 11,770
