Saltar al contenido principal
Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement
Qué necesitas
  1. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement, Brushbar Power Button: paso 1, imagen 1 de 1
    • Gently pull up on red handle to separate the hose from the external hose of the Dyson.
  2. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: paso 2, imagen 1 de 2 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: paso 2, imagen 2 de 2
    • Locate the 18mm four screws on the Dyson above the sticker.
  3. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: paso 3, imagen 1 de 3 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: paso 3, imagen 2 de 3 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: paso 3, imagen 3 de 3
    • Unscrew the four 18mm screws.
  4. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: paso 4, imagen 1 de 2 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: paso 4, imagen 2 de 2
    • Locate and push the grey button (where the index finger is pointing) while simultaneously pulling up on the handle.
  5. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: paso 5, imagen 1 de 2 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: paso 5, imagen 2 de 2
    • Pull on the plastic case below the power and brush bar buttons to separate it from the Dyson.
  6. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: paso 6, imagen 1 de 2 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: paso 6, imagen 2 de 2
    • Slide the buttons out from the case and replace.
Conclusión
Karla Sunjara
Miembro Desde 01/24/17
891 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S13-G1, Banghart Winter 2017 Miembro de Cal Poly, Team S13-G1, Banghart Winter 2017
CPSU-BANGHART-W17S13G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 2,628
