Introducción
Unable to quickly remove your canister from the vacuum body? This guide will show you how to replace the spring inside the opening mechanism.
Qué necesitas
If the top handle does not pop up when trying to remove canister, press the gray button as you gently pull up on the top handle.
Casi Terminas!
Conclusión
