Saltar al contenido principal
Dyson Cinetic Animal Ball Motor Replacement
Qué necesitas
  1. Dyson Cinetic Animal Ball Motor Replacement, Dyson Cinetic Animal Disassembly: paso 1, imagen 1 de 1
    • Press the gray button to release the canister.
  2. Dyson Cinetic Animal Ball Motor Replacement: paso 2, imagen 1 de 1
    • Remove the canister by lifting it out.
  3. Dyson Cinetic Animal Ball Motor Replacement, Motor: paso 3, imagen 1 de 1
    • Find and remove the four 21.5mm screws on the bottom that hold the base plate on using a T15 Torx bit.
  4. Dyson Cinetic Animal Ball Motor Replacement: paso 4, imagen 1 de 1
    • Locate and remove the 21mm screws for each wheel on the ball using a T15 Torx bit.
    • Remove Plastic Disc
  5. Dyson Cinetic Animal Ball Motor Replacement: paso 5, imagen 1 de 1
    • Locate and remove the five 22mm screws on each side of the ball that keep the plastic enclosure together using a T15 Torx bit.
  6. Dyson Cinetic Animal Ball Motor Replacement: paso 6, imagen 1 de 1
    • Remove the bottom half of the plastic sphere to reveal the motor.
  7. Dyson Cinetic Animal Ball Motor Replacement: paso 7, imagen 1 de 2 Dyson Cinetic Animal Ball Motor Replacement: paso 7, imagen 2 de 2
    • Carefully slide the motor out of its housing in the ball.
    • Cut the two wires near the side of the motor using wire cutters.
    • Install the new motor by splicing in the wires.
    • Watch this video by NJprepper321 on how to splice together wires if you are unsure on how to do this.
    • Make sure to match the wires on the motor with the correct wires in the vacuum.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 9-5, Banghart Winter 2017 Miembro de Cal Poly, Team 9-5, Banghart Winter 2017
CPSU-BANGHART-W17S9G5
3 Miembros
18 Guías creadas
4 comentarios
Basic but correct only mine has spade connectors on the motor so no need to cut and solder wires. The problem I found was that the main inner filter was blocked, probably by cement dust who I am guilty of! I would like to know if this is available as a spare part? I have cleaned it for now but it really needs changing.
Tim - Contestar
This vacuum cleaner is based on the DC52 model. The post motor HEPA filter has the part number 922444-02 and is offered by many spart part vendors in the web. Just google Dyson 922444-02. I have made an instruction on how to replare or clean it.
HowThingsWork -
very good instructions, dismantled perfectly.
Allain Ouellette - Contestar
great instructions, dismantled perfectly.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 92
Ultimos 30 días: 384
Todo El Tiempo: 19,138
