Introducción
If you are using your Dyson Multi Floor Upright and there are problems or damages to the electrical cord that are causing issues with the power of your vacuum, the problem is most likely the electrical cord. The best solution to this problem is to replace the electrical cord.
Qué necesitas
Press the red button on the back to release the hose and allow for easy access to the back
Una persona más ha completado esta guía.
Un comentario
Supposing that one doesn't hold onto the front part, and the spring and lever fall out, how does one replace said spring and lever?
