Saltar al contenido principal
Dyson Ball Animal Power Button Replacement
Qué necesitas
  1. Dyson Ball Animal Power Button Replacement, Power Button: paso 1, imagen 1 de 2 Dyson Ball Animal Power Button Replacement, Power Button: paso 1, imagen 2 de 2
    • Turn off and unplug the vacuum
  2. Dyson Ball Animal Power Button Replacement: paso 2, imagen 1 de 1
    • Press the red release button and pull the canister up and away.
  3. Dyson Ball Animal Power Button Replacement: paso 3, imagen 1 de 2 Dyson Ball Animal Power Button Replacement: paso 3, imagen 2 de 2
    • Locate the red dial at the back of the wand and turn counterclockwise to detach the wand.
  4. Dyson Ball Animal Power Button Replacement: paso 4, imagen 1 de 2 Dyson Ball Animal Power Button Replacement: paso 4, imagen 2 de 2
    • Remove the four 15mm screws behind the power button using a Torx T15 screwdriver.
  5. Dyson Ball Animal Power Button Replacement: paso 5, imagen 1 de 3 Dyson Ball Animal Power Button Replacement: paso 5, imagen 2 de 3 Dyson Ball Animal Power Button Replacement: paso 5, imagen 3 de 3
    • Use a spudger to push the two clamp tabs behind the power button towards the middle of the vacuum.
  6. Dyson Ball Animal Power Button Replacement: paso 6, imagen 1 de 2 Dyson Ball Animal Power Button Replacement: paso 6, imagen 2 de 2
    • Detach the power box case from the body of the Dyson after both clamps have been pushed out.
    • Upon removal of this case, you will be able to see a red circular power button.
  7. Dyson Ball Animal Power Button Replacement: paso 7, imagen 1 de 2 Dyson Ball Animal Power Button Replacement: paso 7, imagen 2 de 2
    • Gently pull the power button out of its slot as shown.
    • Detach the power button box from the two wires connecting it, and replace the faulty power button box with a functional one. The power button is the first black one.
Conclusión
4 personas más completaron esta guía.
Hank Wai
Miembro Desde 05/07/17
166 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S15-G5, Banghart Spring 2017 Miembro de Cal Poly, Team S15-G5, Banghart Spring 2017
CPSU-BANGHART-S17S15G5
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 13
Ultimos 30 días: 54
Todo El Tiempo: 6,829
