Saltar al contenido principal
Dynex DX-WBRDVD1 Optical Drive Replacement
Qué necesitas
  1. Dynex DX-WBRDVD1 Optical Drive Replacement, Top Cover: paso 1, imagen 1 de 2 Dynex DX-WBRDVD1 Optical Drive Replacement, Top Cover: paso 1, imagen 2 de 2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Optical Drive Replacement: paso 2, imagen 1 de 1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Optical Drive Replacement: paso 3, imagen 1 de 1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Optical Drive Replacement, Optical Drive: paso 4, imagen 1 de 2 Dynex DX-WBRDVD1 Optical Drive Replacement, Optical Drive: paso 4, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the two screws that secure the Optical Drive.
  5. Dynex DX-WBRDVD1 Optical Drive Replacement: paso 5, imagen 1 de 2 Dynex DX-WBRDVD1 Optical Drive Replacement: paso 5, imagen 2 de 2
    • Detach the tape wires from the motherboard and power board.
  6. Dynex DX-WBRDVD1 Optical Drive Replacement: paso 6, imagen 1 de 2 Dynex DX-WBRDVD1 Optical Drive Replacement: paso 6, imagen 2 de 2
    • Lift the disc drive up to a 45 degree angle and pull back out of the device shell
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 397
