Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Dymo LabelManager 280 Keyboard Replacement
Qué necesitas
  1. Dymo LabelManager 280 Keyboard Replacement, Rear Case: paso 1, imagen 1 de 2 Dymo LabelManager 280 Keyboard Replacement, Rear Case: paso 1, imagen 2 de 2
    • Remove battery.
    • Remove the label cassette.
    Pregunta a FixBot
    Agregar Comentario
  2. Dymo LabelManager 280 Keyboard Replacement: paso 2, imagen 1 de 2 Dymo LabelManager 280 Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove the two rubber feets
    • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
    Pregunta a FixBot
    Agregar Comentario
  3. Dymo LabelManager 280 Keyboard Replacement: paso 3, imagen 1 de 2 Dymo LabelManager 280 Keyboard Replacement: paso 3, imagen 2 de 2
    • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
    • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
    Pregunta a FixBot
    Agregar Comentario
  4. Dymo LabelManager 280 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 2 Dymo LabelManager 280 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Remove the rubber keyboard.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Equipo
USF Tampa, Team 6-5, Eyestone Spring 2016 Miembro de USF Tampa, Team 6-5, Eyestone Spring 2016
USFT-EYESTONE-S16S6G5
Miembros de 3
4 Guías creadas
1Guía Comentario
thank god the bottom feet are not glued in. and the tabs are not difficult
Edward Wijntuin - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 24
Todo El Tiempo: 1,406
