Saltar al contenido principal
Dymo LabelManager 280 Keyboard Replacement
Qué necesitas
  1. Dymo LabelManager 280 Keyboard Replacement, Rear Case: paso 1, imagen 1 de 2 Dymo LabelManager 280 Keyboard Replacement, Rear Case: paso 1, imagen 2 de 2
    • Remove battery.
    • Remove the label cassette.
  2. Dymo LabelManager 280 Keyboard Replacement: paso 2, imagen 1 de 2 Dymo LabelManager 280 Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
  3. Dymo LabelManager 280 Keyboard Replacement: paso 3, imagen 1 de 2 Dymo LabelManager 280 Keyboard Replacement: paso 3, imagen 2 de 2
    • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
    • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
  4. Dymo LabelManager 280 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 2 Dymo LabelManager 280 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Remove the rubber keyboard.
Conclusión
Steven Nguyen
Miembro Desde 02/08/16
431 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 6-5, Eyestone Spring 2016 Miembro de USF Tampa, Team 6-5, Eyestone Spring 2016
USFT-EYESTONE-S16S6G5
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 1,110
