Saltar al contenido principal
Durofix RV332 Motor Replacement
Qué necesitas
  1. Durofix RV332 Motor Replacement, Screwdriver Motor: paso 1, imagen 1 de 1
    • Remove the six 13 mm case screws with philips #0 screwdriver.
  2. Durofix RV332 Motor Replacement: paso 2, imagen 1 de 2 Durofix RV332 Motor Replacement: paso 2, imagen 2 de 2
    • Use the plastic separating tool to separate the casing halves of the cordless screwdriver.
  3. Durofix RV332 Motor Replacement: paso 3, imagen 1 de 2 Durofix RV332 Motor Replacement: paso 3, imagen 2 de 2
    • Once the screwdriver casings have been separated, remove the printed circuit board, battery, LED, and motor assembly from the screwdriver casing.
    • Using the wire cutters, cut the black and red motor wires where they connect to the motor.
  4. Durofix RV332 Motor Replacement: paso 4, imagen 1 de 1
    • Strip the ends of the wires clean with the wire cutters. Strip the wire insulation 1/4" from the end of the wire.
  5. Durofix RV332 Motor Replacement: paso 5, imagen 1 de 3 Durofix RV332 Motor Replacement: paso 5, imagen 2 de 3 Durofix RV332 Motor Replacement: paso 5, imagen 3 de 3
    • Ensure the new motor terminals are clean before soldering.
    • Solder the red wire to the positive motor terminal, designated by a plus sign with a red circle around it.
    • Solder the black wire to the other terminal of the motor.
    • Allow the newly soldered assembly to cool before continuing.
  6. Durofix RV332 Motor Replacement: paso 6, imagen 1 de 1
    • Once the motor has cooled, replace the motor, printed circuit board, LED, and battery inside the screwdriver casing.
Conclusión
Tyler Vincent
Miembro Desde 02/24/14
479 Reputación
4 Guías creadas
Equipo
Un comentario
Too late finding this (although self-explanatory). I was wondering when I tried this - WHERE does one find the spare component motor to replace? I searched the internet, but for something so specific, I just couldn't locate the right channels. For future reference, is there a typical store of small motors, etc... to locate these things?
Arkadiusz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 813
